Want a catch can but..
Ryan698
  • Replies 32
Any other options that won't break the bank that are bigger? I don't really want to be checking daily, maybe weekly.
check out the mike norris can. it is quite large. the main reason for checking so often is the winter when water plays a factor. The W1 does come with a dipstick that you unscrew to check the level. Rather convenient. i only mention daily as for the first few days or week, you may want to keep an eye on the level. Summer would be a lot less. Keep in mind the ADD W1 does come with a baffle but no media in it. i put a piece of stainless pot scrubber between 2 pieces of screen from a dollarama kitchen strainer. Another member here installed layered screens. The can needs a baffle no matter what. The coalescent needs to be dense enough to create large droplets that gravity can pull away from the intake plenum suction and drop in the can
Where did you buy from? I'm also in Canada and would like to keep my purchases in Canada if possible. You went with the add w1?
Went on ebay ordered the black add w1 can the seller was fast shipping shipped the next day cost was 87.99 us plus the shipping so came to around 105 us I believe so not terrible the way I see it our dollar will take a hit this year id rather but it now if I want it then in the summer lol it sucks we pay a bit more but it's a worth while investment.
Sent from my SM-G900W8 using Tapatalk
    Fishboat
    Fishboat
  • Who's Online   4 Members, 0 Anonymous, 556 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
