6.2 8 speed with 35s, anyone?
zoomiejr2
Anyone running a 6.2 8 speed with 3.23 rear end and 35s? Can't find any Aftermarket gears and I wanna know if its gonna be a dog
Sent from my E6853 using Tapatalk
I'm also curious.. I got a Sierra with 8speed I just did 5" lift and 33s. 20x10 wheels are heavy. Was thinking about 4.10 gears. Anyone done it? Or have experienced input?
    zibzer2
    zibzer2
  • Who's Online   3 Members, 1 Anonymous, 799 Guests (See full list)
