I know, been covered 1000's times PO300B code
Frosted Flakes
I know everyone has said to replace the manifold gasket, but I did the carb cleaner thing, no change in idle. Starts and idles fine, no hesitation in the motor when stomping on it. I want to know for sure before I throw more money at this beast. I know I have a lean in the motor somewhere, is there anything else thats been a culprit for this, outside of replacing the manifold gasket?
I don't mind doing the work, just hate wasting time on stuff that doesn't fix the problem. Me and youtube can tear this whole motor apart if I have to!
Any air that gets into the engine without going through the MAF sensor, & throttle body is a problem. Fun part is trying to find where.
The reason I mention intake gaskets is because that was my problem at one time. Similar situation 75+ mph and would only flash when coasting, especially downhill. Gaskets cleared the issue. Is it your problem, I dunno. That's why you go step at a time and rule things out
How many steps are there? I thought I've went threw all the steps!! This is why I'm a welder, you screw something up, cut it and reweld…..done!
I'm going to my trusted mechanic who has a good friend who he trusts, so this should be interesting what he come back with. If he tells me intake gasket, I'm going to kick myself into next week!
You cannot accurately diagnose the problem by spraying around the manifold, the rise in idle speed will be quickly corrected by the IAC and you will get an inaccurate test. It really sounds like the intake gaskets are bad. Can you plug in a scantool and get us freeze frame information at the time of the DTC setting so we can see fuel trims and O2 sensor data?
What about hooking up a vacuum gauge and see what it is pulling at 2500 RPM and above? That will give you a very general idea of the health of the engine, and a vacuum gauge is pretty cheap.
Eric the Car Guy on Youtube has some nice videos on using the vacuum gauge and using the scan tool to look at fuel trims and O2 sensors voltage.
Yep - between him and ScannerDanner, you'll have everything you need to know about troubleshooting.
Gotta love Youtube. Been watching vids all week as I dive into my first German car repair.
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 424 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
