volta headlights keep blowing out
EaZ8
theres having poor preforming headlights then there is having headlights blowing out all the time.
right now ide take less light and at least last for more than a few months.
my CTS i had for almost 10 years and changed the bulbs once...
Due to deer rut coming soon I changed all my lights to LEDs and added aux lights so I could see. All on my dime.
Any info on the bulb setup you used for the low/high beams?
I installed Starnill LEDs in the headlights and the fogs. Bought from Amazon.Used 9005 for the headlights and the 5202 headlight bulbs for the fogs. The fogs are very bright and scatter because of the reflector housing but I have the fogs with the highs beam mod. Added LEDs with a license plate mount from ACI with a remote operated relay and also use one of the garage door openers for backup if the remote battery goes dead. I can see now but hurts the fog and wind blown snow driving because of reflection. No deer hits yet because of lots of acorns this year.
i think im going to be just putting my HID kit in as soon as the weather warms up.
even the upgraded bulbs suck, then lets add in them costing something like $60 each and only lasting 10,000km
Seriously save yourself the trouble and get the Morimoto Elite HID kit. It's so nice finally having sufficient lighting. Super easy to install and very affordable ($170).
i have a HID kit but i really want the service bulletin reversed to have the truck using 12 volts first so im not pumping too much power to whatever aftermarket option i go with.
i think my harness is too short that came with my HID kit so ill need to get a new one. i really wish they wouldnt use the same beam as DRL's...it really just complicates everything...
i opened a complaint with GM Canada Customer service...its not going to go anywhere but lets see.
i am just starting to look at getting my fiancee a new vehicle, most likely next summer...so this may be the tipping point to get her a ram...or a new ram for me and she keeps the sierra...
how do they handle the DRL lower voltage?
  • 1 year later...
just thought i would update this again...
2 bulbs were toast back in june and replaced and now driver side is blown out again.
and now passenger side bulb is out...
Has anyone had headlight issues like this???
I need to be able to reference another truck where they found some sort of fix.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 414 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
