Radio background
Hello!
One thing I do not like is the audio quality (our Traverse has such a better sound system and the Acadia this truck replaced even with the base 4 speakers sounded better) so I will be upgrading the speakers.
Another thing I noticed is the lack of a background on the radio screen like the Lambda vehicles have with their radios. Any way to add a background/wallpaper on ours? I have the Intellilink without Nav (just OnStarNav which I plan on upgrading to full Nav with Carplay one day).
Also, the startup chime is VERY loud even though I turned it down in the radio itself. Any way to turn it down?
You'd think we'd be able to load a picture as a wallpaper and pictures for Contacts in the Nav system, but no, this has come up many times and no one has ever done this or shown us how to.
As far as the chime volume, did you turn it down in settings? Not sure which radio RPO you have, but there was a bulletin with a software update that tones it down a bit. It was only for certain models as I recall. You might want to check with your dealer.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
