I have a th350 4x4 transmission and at times it spits trans fluid out the fill tube whats wrong
Sent from my SM-G360V using Tapatalk
My headers are close too so when it does spot it catches fire
Are you overfilling it? Do you know the proper way to check level? Is it overheating?
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
