2006 Escalade Ignition switch.
I purchased a 2006 escalade that the owner had lost the key, how hard and expensive would it be to replace the ignition switch without the key? Or could i have a locksmith make a key for the factory ignition? My 2006 silverado doesn't have a chip in the key so im assuming neither does the escalade?
Thanks for any help!!
ok thanks, i talked to the local dealership this evening. They said $60 for a new key. Not bad considering it would probably require a locksmith to tear apart the column to get a new one made.
Said just to bring title in my name and drivers license.
Thanks for the input!
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
