Question about suspension
So I don't know much about suspension or body lifts. I was looking to increase the height of my truck while also improving the ride and doing it right.
So I was looking at suspension kits. I have a few questions about them. I am looking to just level the truck (raise the front) or increase the height with a 4 inch lift.
I was looking at icon which sells a set and their suspension says 1 to 3 inches. I assume that means you can extended it up 1 to 3 inches? Would that work without the need of anything else to level the truck?
I also was looking at fab tech and bds sets. Bds only sells a 4 inch suspension lift while fab also sells a 2.5 inch. But they both say I can't use factor wheels. Is that because I would need an offset rim to widen my stance?
Also how much does the ride change with a 2.5 or 4 inch lift? I really want to lift my truck but I also want it to ride wheel and safe. I'm not looking for an crazy lift as I'd still like to fit in the garage and I figure 4 inch or less would do. I am just not sure what is involved or do I need to look for in order to do this.
Also one last thing, ideally I'd like to get a bigger set of tires like 33 or 34 if there is such a thing.
Thanks
Sent from my SM-N900V using Tapatalk
Icon, baja kits, and maxilla suspension kits all offer better ride quality, suspension travel and up to 3 inches of leveling. I am partial to the baja pre runner kit with shocks. Non of those will be cheap options. If you do any real wheeling they all are great.
Sent from the future via a wifi time portal.
Thanks I will look into the others. I was looking at icon and also seeing what bds had.
