Regen notification
Yesterday I noticed that when I was coasting the DIC instant mileage only went to 40-50 instead of the usual 99. Then when I got home I noticed an unusual, though not horribly unpleasant, smell.
Did my DPF do a regen with no notice to me? I never saw "keep driving" or anything on the DIC. e54d3cc790391f521c90c6ed9800671b.jpg
Some must watch while others must sleep
They don't want you to know when the truck is in regen. The only time you will get a message to keep driving if you were to only do very short drives with a lot of starts and stops. When my truck does a regen and I am doing my normal work week drive it takes about 5 10 mile drives for it to complete. I am right at 100,000 miles on my truck and if I did not have the Edge CTS, I would have known about only 2-3 regens in the trucks lifetime. :jester:
I can tell when mine is in regen - RPM's are up at idle, different sound in exhaust at idle and highway speeds, decrease in fuel mileage, exhaust odor and tail pipe is a bit on the warmer side.
I have noticed it takes about 20-25 miles to complete when running at 65-70 mph.
20-30 miles at highway speeds is what it takes to complete a good successful and proper regen.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
