INSTALLING BODY LIFT
It is official.  I have purchased the body lift.  I will be installing it this weekend.  It is nice and long so I can take my time.  I was wondering if you all have any tips.  Now on my tahoe they say nothing about welding the shift extension because it is a cable.  This is true right?  Other than that should I get under there and spray everything with WD-40?  What other tips do you have for me?  Some people here at work are saying that I can't do it myself because there is to much to do.  I say to them it will be no problem.  I want to make sure that I can pull it off.  I was planning a dry run sometime this week.  Thanks in advance.
Later,
Brandon
Spraying WD-40 would be a good idea, especially on the bolts for the bumpers.  I'd spray it on the night before and let is soak in all night.
If you have the 4L60E, which I would imaging you do, it is a cable and no welding of an extention is needed.  I don't know about a manual floor shift 4x4 though.  Someone else may be able to answer that.
I have seen a couple people mention that they installed it completely by themselves, but I had my brother and a couple friends helping out.  I think trying to remove/install the bumpers would be kind of hard without help.  We had a lot of fun doing it, and had enough people to have a couple working on different things at the same time.  Does your kit come with the bumper brackets, or do you have to order them seperately?
Even though yours is a differnt style, and a Tahoe, here's a link to my site with some pics of the install on my '99 Silverado.  It may be useful to give you an idea of what all is involved.  On the left hand side of the page, there is a link to chevy4x4truck's website too, where he has some pics and info from when he installed one on his truck.
Body Lift Installation
Good luck and have fun.  :thumb:
1. Get a friend to help. Two sets of hands is sooo much better than just 1.
2. Use a 4x4 vice 2x4 to jack the body up. The 2x4 I was using kept sliding.
And most importantly, TAKE YOUR TIME. It's not a race, spend a whole saturday on it if you have to, just besure to follow the directions.
I installed a PA 3" lift on an 87 S-blazer by myself once, it was very simple, didnt seem to hard to do alone, but since you have a longer, heavier body, you might want another guy or two on the job with you.
-John
two words.....Breaker Bar
also might wanna check out a shop manual, my blazer had 2 hidden bolts on the tailgate hinges that attatched to the frame.
GOOD LUCK :cheers:
