1997 gmc sierra front brake
i have a 97 gmc sierra 2 wheel dr the driver side front break pads are rubbing hub reel tight not locking up but enough that they will get hot and smoke and get real hot i have changed caliper, rotor, and break pads.changed pads on both sides rotor and caliper were in good shape on passenger side. any suggestion on where to go next to fix problem would really be great thanks cliff
some simple things..
does abs and brake light come on and go off in some seconds after key on?
a bad bulb drives abs crazy.
I tried LED for weird things to happen..went back to regular to fix it.
the regular old bulb is a resistance value in the simple computer.
bad bearing will rely on rotor to align CV or bearing... up against the pads and caliper.
could check torque on the nut, simple stuff first.
A loose one does not need to make noise.
the abs stuff kicks no errors as well, last of the old computing. This gets tricky... you may be pressuring from a bad abs function.
Try replacing rubber brake line to caliper. These will get old and collapse....not alowing fluid to return.
yes that is what i would suggest. i have also heard of bad servos that stick and do not allow fluid to return. test the abs, go down a dirt road and slam on ur brakes. if the tires lock up for more than half a second their is something wrong with it.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 281 Guests (See full list)
