Only one speaker works
As in the title only one speaker works. My right door speaker. I believe it's all factory. Could the other 3 speakers be completely blown or head unit bad? What's the best way to test speakers and narrow down if I need speakers or a head unit or maybe both?
The two front ones are universal side to side. Take both panels off, swap the good speaker to the bad driver door one, then take your balance and fade and set them full to that front speaker. If it works, then you know you have a dead one. Speakers are pretty common on GMT-800, especially the driver's door.
With 214,xxx I figured I'm probably going to find lots of little things worn out. I was more curious if speaker wires could be tested for voltage???
If I swap speakers and the others still don't work how would I narrow down if it's in the wiring or the head unit? Without tracing down all of the wiring that is.
could be broken wires in the loom that goes between the door itself and the cab. My left rear did that to me. You could do a continuity test if you have a meter. Just unplug the head unit and the speakers and the leads to the meter should be able to reach both ends.
continuity test is good. but do you have a factory amplified audio system? either bose or when you pull your radio is there a smaller 7ish pin harness with a pink wire in it? if it has either of those a continuity test wont do much good unless the car is running with volume low (say 1).
But a really common is rot in speakers and for the surround to disintegrate leaving the cone separated from the basket which leads to distortion and eventual mechanical failure... look at the speakers and see if they have separated that way..
if you have a meter test for ohms... each should read around 4 ohms... maybe 8... slight chance of 2 ohms.... if it isnt between 2 and 8 and is say 4000 ohms or just reads 'OL' then the voice coil is fried... but the speakers go bad easily and often. upgrading is easy and always worth it.
Are you saying remove plug from the speaker and check to resistance to the head unit with it on? I'm pretty sure that wouldn't get any good results. I was more seeing if there is any working voltage to the speakers so I wouldn't have to remove the head unit and unpleg the speaker and check each side individually. Across the speaker should be around 4 ohms. When I get a chance I'll remove the door panels and check the speakers. Also I have no idea on what system. Truck is an sle and appears to be 4 door speakers and a standard? Head unit.
not resistance to the head unit. resistance of the voice coil in the speaker. so plug one side of the meter to + and the other side to - and see what it reads with the system off. or unplug if you want.
checking continuity to the head unit is the way to test to see if the wires are split. or you can meter AC at the speaker to see if signal is being received by the speaker. continuity is more time consuming as it requires both radio and speaker to be unplugged. where as AC is tested right at the speaker leads in the door.
    • I have an Autel, works great for what it is. Can't do some specific things because you need say the GM tool, VCDS for Audi/Volkswagon and others of course. But those times are few and far between for me.   The other tool I'd like to try one day is the new Topdon scan tools. Seen several video's on them and many youtube people review them.    I've never subscribed for updates or payed to do that stuff on my Autel, so I'm sure I'm missing out on some of the updates but I'm fine with that for now.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
