Tow mirror running lights..big problem need help
I went to install some smoked klearz lenses on my tow mirror clearance lights today. Put them in the oven to soften the glue. Low temp for 12 minutes, center of oven, on a pan and they came out warped! They are warped beyond use and are no good at all. I've been searching the internet but can't seem to find just those for sale and i certainly can't afford to buy a whole new set of mirrors to get them. They have part numbers on the backs of them 807018 and 807019. Can i get them anywhere? I'd think gm would sell them separately in case one of the led's burned out or had an issue? I've baked headlights and other pieces before and never had an issue I don't know what happened... Thanks in advance
12 minutes is enough to melt any hard plastic. I usually bake them for 7 minutes max at 265 degree. I don't think GM would sell just those. you have to buy the whole new mirror.
I did 225 for 8 minutes at first and it didn't do a thing. Couldn't even begin to get anything between them to get them to start separating. Put them back in for a few more minutes and they are now junk.. Really stressing me out
I had asked a similar question a while back and received this info. I found them on ebay for $75.
The entire LED amber lens/lamp assembly for the driver side is p/n 23444106, 23444105 is the p/n for the passenger side amber mirror lamp. No...you don't have to buy the whole mirror.
Changing it on the other hand...a bit time/patience involved. You have to remove both mirror glass pieces:
Then you have to remove the mirror bezel (the black frame that is around the glass, has the tapered shield for the cargo lamp) by removing the screws that hold it in place, then you can get to the screws that hold the lamp in.
I ended up getting some from GM.. All done and installed on the truck now. That was an expensive mistake. Thanks for the help.
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 539 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
