NEW Profile Fields
Zane
Everyone should note the addition of three new profile fields!
There is now a place for your full name & truck make/model.
So, if you have a chance, go and fill them out!
We're also accepting ideas for other custom profile fields if anyone has some ideas. :cheers:
I wish we could have our location automatically displayed. The board is really looking good....
I kind of liked the little light bulb that indicated when someone was actually signed on right then.
Also, maybe more than one place for make/model?
Ive been here a while and i still dont know how to tell which threads ive posted in?
Is there some indicator or something?
Do you mean like subscribing to a thread or tracking a topic? There is a Track this topic in the blue border at the top and bottom of a thread. If that's not what your talking about, then I'm not sure. :cheers:
Is the "tracking" an email that gets sent out to you or is it a special icon that is visible on the thread?
Im certain ive checked that option before but have never gotten an email.
I sure wish there were icons like on FSC.com or hometheaterforum.com and countless other forums.
Much easier to track a topic.
I don't knwo about tracking a topic that you "posted" in, but on mine, it puts a little blue icon next to the topic of every new post since the last time I viewed the forum. It's to the immediate left of the topic title, looks kind of like a little check mark, and takes you to the last unread post in that thread. Also the icons on the main forum page are colored a darker blue when there is a new post in that forum.
To be honest, I've never used the "track this topic option" here, so I'm not sure what it does exactly. I'd guess it sents an e-mil. I'll track this one and see waht it does and let you know. :smash:
There is an envelope to the left of each topic. Blue is less than 15? posts. red is a "Hot Topic" (lot's of posts). And if it has a dot in the middle of the envelope, then you have posted a reply inside the thread.
After Shane replied, this is the e-mail I received:
MountaineerTom 99Z71,
Shaners has just posted a reply to a topic that you have subscribed to
titled "NEW Profile Fields".
The topic can be found here:
http://www.gm-trucks.com/forums/index.php?...=ST&f=1&t=18718'>http://www.gm-trucks.com/forums/index.php?...=ST&f=1&t=18718'>http://www.gm-trucks.com/forums/index.php?...=ST&f=1&t=18718'>http://www.gm-trucks.com/forums/index.php?...=ST&f=1&t=18718
There may be more replies to this topic, but only 1 email is sent per
board visit for each subscribed topic. This is
to limit the amount of mail that is sent to your inbox.
Unsubscribing:
You can unsubscribe at any time by logging into your control panel and
clicking on the "View Subscriptions" link.
Regards,
The GM-Trucks.com team.
That's how the tracking ption works.
The info Shane posted is correct also. I never knew about the dot in the middle though. I always just check the ones that are brighter than the rest, or hit the "view new posts" or "todays active topics" link.
Yeah the DOT thats exactly what i was looking for, but i had no idea it was there.
Is this new to this board, cuz i seriously dont remember a dot on the last board.
Ill have to take a look.
Nope :thumbs: no dot on the envelope. I went into my "controls" section to see if there was somthing i needed to check but cant find anything.
I know im accepting cookies cuz i get the little "dot" on other boards.
Anyone know for sure if there is a dot on the envelope of threads you have posted on?
Hmm, I'm not sure what to tell you Henry. I looked in my Control Panel, but didn't see anything that stood out as far as the "dots". Maybe Zane can answer it, I'll pas it on to him.
There are a couple ATV sites that I go to that I have similar type problems with, like not marking only the new posts since my last visit. I've looke all over my setting at those site, but can't find anything there. :thumbs:
