2015 5.3L Header Torque Specs
Hey guys! Anyone have any insight on what the torque specs are for a header install on a 2015 silverado 5.3l. I need to know how tight to make these bolts.
Kooks instructions say to tighten to factory exhaust manifold torque specs.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,276 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
