Custom LED Reverse Lights
Well with tinted windows, and soon to be tinted taillights, I needed something that was much brighter than stock.
I figured 900 lumens each should do the trick.
I didn't want to add LED cubes under the bumper. I like the clean, sleek look and didn't want anything hanging below the bumper. So I came up with this.
Firstly, I bought the Mini LED cubes from superbrightled.
Specs on the lights: 2x2 inches
60 Degree beam pattern
10 W
900 Lumens each
6500K color temp
I traced the light size out on the taillight and cut the square with a dremel. This allowed the light to sit down inside the housing a bit. Then I just glued the lights in with PL Premium Construction Adhesive. Plenty strong!
To wire them up. I tapped into the reverse light wire on my trailer package. I was going to tie right into the reverse light at the taillight, however the trailer reverse lights is separately fused. (lime green/white wire) I just ran a ground down to the frame. The light came with male and female waterproof connector so when i want to remove the taillight, the reverse light has a quick disconnect as well.
I just removed the bulb from the stock reverse light, put dielectric grease in the socket and taped it off with electrical tape.
I am extremely happy with them. Would recommend this mod to anyone who is willing to cut up their stock taillights haha
They are awesome at night. I will upload some night pictures soon. Never got a chance to take some. But they are awesome.
10 W
900 Lumens each
6500K color temp
Looks great do you have any pictures of them on at night?
Sent from my SM-G925V using Tapatalk
will grab some tonight. Rained lastnight and didnt feel like taking pics haha
Are the tail lights a hassle to remove. I'd just look but the wife has the truck.
Only 2 screws hold the tail lights in. Easiest thing to do.
How does the camera look at night?
Sent From My Galaxy S6 Edge+
I was also worried that it was going to effect the camera because they are so bright. However, it didnt effect it that much. The camera goes whiter/lighter, however you can still see fine.
It really doesn't change it that much.
    Afennell19
    Afennell19
  • Who's Online   3 Members, 0 Anonymous, 871 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
