Maybe I'm missing it, but the videos I've seen don't show access to the housing where I'd replace the nut...
I took the panel off and like I mentioned there’s no access to the handle housing. How difficult is it to remove the rest and reassemble? At this point do I bring it to a body shop?
  • 2 months later...
On 5/24/2016 at 8:41 PM, 15GMCSLT said:
So I literally just done this too! I was changing my plastic black handles to painted white, searching for the bolts if you still have these let me
know! I will be taking the panels off today, well attempting it. I did my front doors right.  just need to get my bolts for the back out.
  • 2 months later...
On 5/24/2016 at 6:41 PM, 15GMCSLT said:
Well here is the mysterious nut and bolt for the door handle. The new parts that came in had an extra set that I don't need. You still have to pull the door panel to instal these. But have have extra if anyone is interested.
How did you install the nut? I’m having that issue right now.
  • 6 months later...
When I backed out the screw and tried to reinstall it with the new handle piece the nut looks like it has shifted further into the plastic section. I’ve lost the ability to screw in and get it to hold without the nut. Has anyone else experienced this problem?
  • 8 months later...
Any help on replacing the nut? I am in the same situation as others. Actually after many internet searches the answer was right in front of me the whole time. There’s a bolt behind where the exterior door handle mounts that needs to removed. This will allow the door handle bracket to be lowered and the nut can be reinstalled.
Edited by elucas78
