FastHeadlights - FXR Bargain
Yeah I talked to fast and he said if I sent him the eBay headlights he could make a adapter but I'm going to have to pull the eBay headlights apart anyways so I may just retrofit regular halogen ones
WARNING:: if you dont already know, these are permasealed headlights and are a PITA to open!!
  • Replies 38
Yeah I'll either bake them if I can't get them that way I will cut them open
  • 1 month later...
  • 3 weeks later...
    zibzer2
    zibzer2
  • Who's Online   3 Members, 1 Anonymous, 799 Guests (See full list)
