Best sounding performance muffler
Just got this awsome tip in I ordered from amazon 191f5f9385b0214210f0933b72850197.jpg I'm just holding it up to see how good it's gonna look. I wash just gonna do a muffler delete, but a guy here at work said it would mess my truck up, said it would loose back pressure mpgs would take a crap. And void a warranty. I don't see how. But we should do a pole and see who's leading the way in performance mufflers or muffler delete
  • 2 months later...
Lots of exhaust system threads on here. I personally had the dealership install the GM Borla cat back system on my 16 Denali 6.2 last week and I am very pleased with the sound. Just a deep rumble at part throttle that turns into a very impressive louder sound when opened up. Cost is a bit prohibitive but if you cut out beer and cigs for a few months you should be able to afford easily. https://youtu.be/0J1ah88JmdA
I'm running a Corsa muffler and I love it. Sounds great and is a completely straight through design. Borla is also another you should consider, they're both some of my favorite "performance style" mufflers. I used to run flowmasters, so long as I'm able to I'll run anything besides them.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 757 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
