Looking for shocks for 6" lift
I recently purchased a 2015 with a lift but the person I bought it from didn't know anything about the lift. The best I can tell it is a 6 inch. The truck was bought from the dealer with the lift already installed. It looks like it my be a Zone lift from pictures I've looked at on the net. There is nothing identifying on the lift.
One of the rear shocks are damaged and I want to replace all four because I'm not impressed with the bouncyness. I'm going with the Bilstein 5100 for the front. But I just can't seem to find the correct 5100 for the rear for 6" lift. Can anyone help me with this? Thanks
One question I have is can you replace front struts with shocks?
Sent from my SAMSUNG-SM-G930A using Tapatalk
The fronts aren't actually struts from what I've read. The shock is just housed inside the spring. Either way, you can just change the shock inside the spring or you can go with full coilover such as Fox and Bilstein has one coming out supposedly pretty soon.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
