Coil Covers Pull off?
Want to paint the coil covers .. cant see bolts, so thinking they pull off??
Remove oil cap one side, PVC hose other first.
Before I yank on em and break something, thought Id ask first
OK answering my own post lol.
For the next guy - yep they just pull off.
Both sides are tight at the back and you need to slide em up tight to the firewall.
First time I tried they wouldn't budge.
Used a step stool this time for a better angle and they popped free easy.
Painted and re-installed ... cheap mod
