Flowmaster super 40 muffler
Just bought a flow master super 40 muffler off of a buddy with a 2015 silverado. Looking to put it on my 2015 silverado but have the stock exhaust. What all needs to be done to get it to work. Still going to try and use some of the stock pipe. Looking to do it so I can flip back to stock easily.
Depends on what the in/out on the muffler is compared to the stock exhaust and their respective size to the stock exhaust. IE: What model Super 40 is it?
http://www.flowmastermufflers.com/?page_id=11131
If it's the same size as the stock and just a 1 in/1 out that lines up with your existing muffler, it should be pretty self-explanatory.
Here are some results I found with a quick Google search:
http://lmgtfy.com/?q=flowmaster+super+40+install
Well, your truck should be 3" so, as long as the in for the muffler lines up it should be a simply muffler swap following one of the basic guides from Google's search results that I linked.
