Brake Fluid Flush - 2013, couldn't believe how bad
I just did a brake fluid flush on my truck using a Motive Power Bleeder. I can't believe how gnarly my brake fluid was on a 2013 with 65k miles. It was totally opaic green, it was in really bad shape. I would strongly recommend that everyone think of doing this or having it done. FYI, GM doesn't recommend the Supreme 11 brake fluid anymore, there is a new ACDelco part number, 19299818.
"Always use the new DOT 3 brake fluid when refilling or servicing the brake system. If another type of DOT 3 brake fluid (including the GM DOT 3 Delco Supreme II) is used to refill the master cylinder, it may cause a master cylinder squeak noise. If the wrong DOT 3 brake fluid is used, remove as much of the old brake fluid from the master cylinder as possible and refill with the new DOT 3 brake fluid. Depress and release the brake pedal five times to allow the new fluid to enter the system.​"
I have had a lot of luck with the Motive products power bleeder.
