phone dock mounting - GMT900
So for the last 5 years i've tried to come up with a good way to dock my phone in the truck. I don't have a center console just the arm rest with the three cupholders. I have a Motorola dock that has the big suction cup on it but i don't like the idea of putting in on the windshield since it's so far away. I tried sticking it to the textured panel under the radio but since it's curved it just peels the mounting pad away and falls off.
Where have you guys mounted your docks for easy reach, simple wiring for plugging into the aux audio port, and a clean install. my dock has the 1/2" ball receptacle so if there are any mounts out there that work i'd like to hear about those too.
In the end i may just pop for an android auto head unit but that's $$$$.
What are the options?
Put the suction cup on the dash, right above the big screen. Just make sure the dash is clean and dry and it will stick on there, mine's been in place for over a year.
Ran into this same problem with a GPS unit trying to use a suction cup on the textured surface. Went on ebay purchased a 3M plastic disk that has very good adhesive on the back. Figure out where you want it for good peel off the back of the disk stick it on wherever. Then take the suction cup and it will attach to the plastic disk until you remove it.http://www.ebay.com/itm/90mm-3M-Car-Dash-Dashboard-Adhesive-Sticky-Suction-Cup-Mount-Disc-Disk-Pad-4-GPS-/262055281026?hash=item3d03b64182:g:cOgAAOSwHnFVg3eT Here is an example of what I used.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
