Morimoto 2Stroke LED bulbs
Either I don't know how to properly use the search function or there really isn't any topics on this yet
https://www.theretrofitsource.com/led-lighting/led-bulbs/2stroke-h11-led.html#.V38tSZA8KK2
Has anyone installed these yet? I like my HIDs but have DRL kills the bulbs in about 10-12 months
I would like to know about performance and figment with the provided dust caps
There is a video on YouTube about them. Also join headlight junkies on facebook, and there is a post on them there as well. Other than that there isn't much.
Also you have to cut a hole in the back of your stock dust cap, and mount the rubber dust cap from TRS in the hole. It's a 60mm diameter.
So the dust caps shown in this picture are not included?
morimoto_2stroke_h11_h9_h8_led_headlight
Yes they are included. They are 60mm caps. You have to cut a 60mm hole in your caps then stick the ones in the picture in the holes you cut in your stock ones. They designed them this way so they would fit in the majority of stock dust caps on the market.
I'm going to give them a shot. I've got a complete Morimoto HID kit ready to install, but this seems more up my alley as far as install goes.
I couldn't find it will you post the link to it and post pics in your thread of the install?
What worries me is that they will have a very intense hotspot that will shine way too much foreground light which week make them no more effective than halogen.
So these are in but BIG problem
They look great and seems good enough
But
As soon as I turn the truck on and into drive
They immediately go off
As soon as the truck is off and then locked again, they come back on.
Wtf is going on here
Don't think so. They do come on fine-again when the truck is completely turned on. I may be mistaken but a polarity issue wouldn't come on intermittently no? It would be either all on or all off?
When they were in and on they looked great for sure
Now the issue is to keep them on
Going to be calling TRS on Monday. I want to make these work
  • 4 weeks later...
Any updates here?
I just purchased a set of led's for my headlights that are 4000 lumens per bulb and they look really good and are super easy to install but going out on the highway they really don't produce as much light as i would've expected, they cover a good distance but its not a really visable light.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 540 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
