Morimoto 2Stroke LED bulbs
  • 1 month later...
  • 4 months later...
Hey JerseyTaylor, did you have any success getting these lights to work? I just installed them in my 2014 GMC Sierra, and same issue. Worked just fine when they were being installed, vehicle off, but as soon as i started truck they would turn off and no way to get back on. Seemed to have better success without the anti-flicker harness installed, but still no dice on getting them to work. Very frustrating because I have tried an HID setup, with limited success but don't work 100% of the time, like headlights should.
So these are in but BIG problem
They look great and seems good enough
But
As soon as I turn the truck on and into drive
They immediately go off
As soon as the truck is off and then locked again, they come back on.
Wtf is going on here
You will have to use the same harness with the relays that would use for the HID kit.. TRS sells the Morimoto harness.. I went through 5 sets (all different brands) of LED lights before I finally figured it out.. IMO, no matter what LED kit you buy, it will never compare to Morimoto HID..
just went HID.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
