Time for the dyno.
$650 for headers & a tune has to be at least $3-400. $1000 for 10-15 hp. Is it worth it? Which Texas headers would be better, off road y pipe for more power or the catted Y pipe for emissions? Of course I have emissions in my county but I think they just plug into the OBD to scan.
It's not really the numbers that count...I mean they do.
I know for a fact my truck will dyno over 300 to the wheels with the right condition. As far as actual driving difference it's totally worth it! The way it shifts, accelerates and the tourque it now makes makes driving the truck much more pleasurable.
The truck is a lot quicker than what most people think.
I can echo this on my 13 Sierra. The numbers don't lie, but they also are not the end all be all. Drivability in my truck is drastically different after the tune. Headers gave the truck a good amount of power all through the curve, and sound great...
If you are doing mods based strictly off $/hp, then there may be better paths to go, but this made me much more satisfied with my DD
Sent from my SAMSUNG-SM-N910A using Tapatalk
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
