New 2016 gmc z-71
Just bought a 2016 4wd 1500 gmc slt cc. Decided on toyo at2, but cant decide on what size. Pretty sure Ive got it narrowed down to 305/55/20, or 295/60/20. Wanting to run level kit only, no lift. Looking fir pics, advice, etc.
I was in the same position you are, I decided on 295/55/R20. I have a 2.5" level and the only rub I have is on the driver side in reverse at full lock, and it's only on the mud flap so if you don't have mud flaps you should be fine. My wheels are 0 offset and the tires stick out from the wheel well about an inch which gives it that perfect stance in my opinion, without that stupid look when tires come out 3-4". The reason I chose the 295 over the 305 is the 16 lb difference PER TIRE. I'll post some pics in a min
Sharp truck!! Thnx for the response. I may consider the 295s as an option too. Im 99% sure im gonna run stock 20s. So im trying to research every option cause im pretty damn particular
Does anybody have any pics or experience with 305/55/20 or 295/60/20 on stock gmc 1500 wheels, 2014 and newer?
Before my BDS 4" (2" level) tire size 305/55r20
I'm going Saturday to get new tires on mine. I'll be looking at the 305/55 and 275/65 on a stock wheel and 2.5" level. I'll be sure and post a link or a pic when I get em
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 485 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
