1886 GMC 1500 ignition module getting hot
I have a 1986 GMC 1500 that is showing a 42 code We have replaced ignition module the ignition timing module and the distributor. after taking the truck up the block and coming back the truck sputters and shuts down any thoughts of what this could do would be helpful
I normally don't even look at codes on OBD-I vehicles. 90% of the time they're not really helpful in diagnosing drivability issues.
Double check that all your wiring is connected correctly. Make sure a ground wasn't left loose if it attaches to the base of the distributor. Make sure you've got battery voltage, key on, on the appropriate wire, and a good ground in the harness as well.
These days there's also a good chance of something being junk right out of the box. If all else fails, that would be my suspicion. Sometimes it's tough to return electronic parts - depends on the retailer. Most won't, since it's so easy to turn the components into paperweights by hooking them up wrong.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
