15 ez lift tailgate
No way to adjust it and it seems to be a common problem with them getting weaker over time. They also drop faster during hot weather and slower during cold weather. Mine now drops in just over a second in 90 degree weather and just under 2 seconds when it is 70 degrees in the morning. I am going to see if they will replace the torsion bar under warranty.
I put a tail gate mat on mine and with the extra weigh it drops faster but it isn't all that bad. And no there isn't anyway to adjust it
