Transmission Temps.
Even though I have the DIC with the Transmission Temp, I don't really use it.
The other day it was 105 degrees outside and as I was looking at the trans temp it said the temp was 192 degrees.
What is a normal temp area for the transmission?
I have the 4 SPEED,4L60E,Electronic 4-SPD A/TRANS(M30) that came in 2009 with the 5.3L V8.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
