New phone, problem with Intellilink
I got rid of my iPhone for a Samsung Galaxy S7 Active. My old phone would work with the USB to play music, but my S7 does not. I can use the bluetooth option, but I want the USB capability.
Anyone have any ideas??
Thanks!
Thanks!
Have you downloaded the android auto app?
Sent from my SM-G930V using Tapatalk
I have a 2015 Sierra, will android auto work? I thought it only worked for the 16 models.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
