2016 silverado 1500 headlight bulb upgrade
On 8/18/2016 at 10:15 PM, 1300c said:
If you have a 16 model that's not a ltz, or high country you have hid. However since they are d5s bulbs they are only 2200 lumens instead of the 34-3600 lumens that a d2s bulb is. Your bulbs have a smaller 25 watt ballast that's actually attached to the rear of the bulb. You could probably easily upgrade to base d2s cbh bulb with a 35 watt ballast and blow the oem led headlights away.
So what if I have a 2016 1500 ltz what do I have? I been looking and looking for HID lights and I can't find one...on the filter it only shows the 2500 and 3500 for the 2016 models....any ideas
  • Replies 69
With that model you likely have LED headlights, in which case you have some of the best headlights money can buy. I wouldn't trade LEDs for HID any day of the week, in fact I have the 25w HID and I wish I had 25w LED.
Pros of your LED:
-Instant on/off with no warm-up or cool-down
-Slightly better amp efficiency (barely)
-Super long life in quality diodes
Pros of HID:
-You can get SUPER BRIGHT and blind everyone if you want to
Also, since you have the factory LEDs, you will have a hard time replacing with HIDs without replacing the whole projector.
If you are really set on HID, i have half a mind to trade my 2016 LT headlight assembly for your LTZ assembly... :D Cheers
In case ill just stick with mine lol...thanks for the info man.........but theres better leds that i can add that will make them brighter right?
Probably not, these new led fixtures are hardwired and custom fit and never use any standard bulb base.
But you can always get supplementary lights like grille or sport rack lights if you want more light.Plus they look pretty sweet, I'm a big fan of the amber led grille lights personally cuz they work great in fig and snow as well.
On 5/15/2018 at 8:37 PM, AtlasFBG2 said:
If you want plug and play 35w d5s hid for your 2018 there is 3 choices.
Morimoto for about $320-350 depending on where you buy.
Hylux and ddm tuning for $199
https://hidkitpros.com/shop/hylux-d5s-oe-headlight-xenon-hid-bulbs/
http://www.ddmtuning.com/Products/Ultrakit35WD5S
http://www.fastheadlights.com/ProductDetails.asp?ProductCode=buy_35watt_d5s_HID
I have the Morimoto 35w d5s and while they are brighter distance is still about the same as the stock 25w d5s bulbs.
How do the Hylux compare in quality to morimoto ? Wh6 are the morimoto two much more?
I got the DDM off of Amazon, look just like the hylux, 4300k. Very happy with increased output. No they don't project out further,  it isn't that more of a function of the reflector design? The light is slightly more blue than factory, closer to the color of the fogs. They come on pretty fast and in the 2 weeks I've had them there have been no issues with them coming on.
Ltz had LED already.  Which is better than the hid lights in my opinion
    fourhorses88
    fourhorses88
  • Who's Online   4 Members, 0 Anonymous, 875 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
