strange jerking issue
Ive had an intermiddent issue for about 3 months now, but it's getting close to undrivable
Its a 2002 suburban with a 5.3
At first from a dead stop there would be a bit of jerking and that lasted for 2 weeks then went away. Then cruising at highway speeds(55 or higher) it would randomly jerk, maybe once a trip. Then it started doing it every few seconds. Then I went 2 weeks with no issues.
Finally this week, every time I went over 50-55 mph it would jerk hard every 2 seconds or so and I finally got some CELs to scan.
P0343 - Camshaft Position Sensor A Circuit High Input (Bank 1)
P0342 -Camshaft Position Sensor "A" Circuit Low (Bank 1)
P0336 - Crankshaft Position Sensor A Circuit Range/Performance
Also along with the jerking the car will randomly stop responding to the gas pedal for 4-6 seconds, it will just start slowing down and then the rpms will drop to where it almost stalls, then(if im holding the gas) it will shoot back to life and start responding again.
Ive changed the camshaft position sensor with one off of a working motor so far. Still getting the jerk.
Any ideas? I appreciate all help as this is my only running vehicle at the moment
  • 3 years later...
I’ve got a 99’ Silverado and it has similar problems on the freeway, with the jerking. But with hard starts mainly. I replaced the Crank sensor With no avail.
P0343
I’m going to replace the crank position sensor Connector. And check the wiring to the ecm I believe.
if that doesn’t work, then I need to probably replace the fuel pump.
if anyone else has fixed this please let me know.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
