2016fifteenhundred's Silverado Crew Cab LT Build Log
90% sure this bad boy is going to be under the tree from the wife, pretty stoked. This is a 12" JL TW3 Shallow Mount subwoofer in their "power wedge" box.
I'm going to run it on a Soundstream RN1.2000D at 2 ohms which gives me 600 watts RMS. The amp just came in yesterday, it's crazy how tiny it is! These Rubicon Nano's are pretty slick, and super affordable, too. 15241139_1478807052133466_77141322036860
  • Replies 31
Well Christmas came early, the subwoofer came in the mail and the company she ordered it from did not put the factory packaging in another box and I was the one to sign for it. She was not happy with them I will tell you that much. But on the plus side I installed my RN1.2000D and the TW3 12 last night and man this is exactly what the stereo needed. It gets loud when you want it to but it's not overpowering. The bass sounds full, not hollow like other shallow subs I've auditioned. I have to be honest I was really skeptical about using a shallow sub, the previous shallows I auditioned did not have the sound you look for in a subwoofer. This TW3 definitely does.
I'm feeding it 600 watts RMS which is above what it's rated for but all of the research I've done says it can handle it.
In other news I've got new dash speakers on the way, Sundown Audio SA-2.75. I will post pictures of the install on those as it seems to be kind of a hot topic around here.
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
