Loss of oil pressure
I have a 2004 Tahoe with a 5.3 flex engine. I have been having issues with the oil pressure for the past 2 years. I can drive for 3 months with no issue and then it starts acting up by loosing pressure and sending the system into alarm. I took it to the dealer and they said it had good pressure. I replaced the oil sending unit and thought everything was fine. I had it out and pulled into traffic, pulling about 5500 rpm's and shortly after that, the pressure dropped and system went into alarm. Checked oil and it was only one hole down on stick. Figured it was just the screen or switch or cluster, went to go home when the engine started knocking, bad. Turned it off and tried to limp it home. After 5 min stopped, the oil pressure returned and everything looked good. Went about 10 miles and everything was good when it dropped again. Then it returned again. Got it home and oil on stick was only one hole down on stick. Does anyone have advise? The engine only has 130000 on it. I do loose about 1 qt of oil every 500 miles. and loose about 1 gal of coolant every 10000 miles. Never see any smoke or leaks. I am thinking I need an engine overhaul, but only 130000 mile out of an engine. Seems that I should have got more. I have owned the truck since new and changed oil every time the oil sensing system got to 10 percent.
Couple of things to add, it should read I am loosing 1 qt of oil every 5000 miles. When I took the truck to the dealer, it was in alarm and the engine was knocking, slightly, when the pressure was low. The dealer said the pressure was ok and the gauge on the cluster was bad. Dealer said the knocking was from the cam. Do not know how they determined that, but knock went away when pressure returned. I have gone all summer without an issue. It seems that I get these issues when I rev the engine over the 5000 mark. After a while everything returns to normal. This time the knock was bad, and almost cut off. I know, just do not rev the engine..... but I like too.
Missing coolant could be a few things. Intake manifold gasket leaking, or more commonly water pump going bad which will slowly weep coolant which is hard to detect until the leak gets worse. Maybe take it to another mechanic for a second opinion?
Replaced the water pump 18 months ago. Slowed the leak down. I believe I burn water when I start up but stops when engine gets warm. I saw this was a common problem with the head gasket. My biggest concern is the oil pressure with the knock.
Another problem they have is the o-ring on the oil pick up tube. When the engine is running that part of the tube is NOT submerged in oil, if the o-ring is shot, it will suck air and cause this issue too.
I looked at the screen, but that would only explain the loss of oil pressure, I have noise when the pressure gauge goes down, this would tell me that I am losing pressure to the engine, or part of it. Did not know about the o ring. Might explain symptoms, this only really happens after I Rev the engine high. Symptoms of losing pressure and it coming back and various back and forths.
Your AFM lifters are probably crapped out.....
04's don't have AFM lifters.
From my personal experience with oil pressure issues, I replaced the oil pump, and the pickup tube. The knock, which almost sounds like a diesel, was the lack of pressure causing some lifter knock. Just my experience may not be your issue. Mine was on an 05.
http://www.gm-trucks.com/forums/topic/151001-2005-gmc-sierra-1500-4x4-53-oil-pickup-tube-o-ring-replacement/
This is what I was thinking. Did sound like a diesel
Looked at this post. Says only 7 hours to remove front diff and drop oil pan to replace oil pump. Very doable. With the head gasket issue I think I have (losing water and oil over time), I think I might just rebuild the whole engine. I love the truck and body/undercarriage looks good. Wife hates the newer designs, wants to keep truck as well. I will look into both fixes and update on which way I go.
I replaced mine without dropping the front end. It's actually pretty simple and saves a BUNCH of time. Make sure you have a flexible magnet and some fishing string ready. So when GM put the oil pumps on our trucks they added a flange on and all you need to do is remove the keyed piece stopping the flange from spinning around because right there where it would be easily accessible if you turn the flange 180 degrees is another bolt hole for the pickup tube.
Not my video, but he did what I did.
did that almost 40k miles ago.
Great advise, thanks
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,434 Guests (See full list)
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
    • Do you have access to BP fuels? Some stations have Silver 91 E-0 priced the same as their 93 E-10.  There is a local Marathon with 90 alky free for $6 a gallon but I go down the road to BP for $5-ish. They also have a 100 E-0 but that stuff is $10 a pop.
