2016 gmc sierra grille on 2014?
Moxy1122
Hi guys. New to the forum. I just purchased a 2014 sierra texas edition z71 and love it. However i like the grille of the 2016 sierra which has the the vent/opening at the top middle. Does anyone know if one of those grilles will fit my 2014?
The entire front clip is different. Hood, bumper, grille. You'd have to change all three from what I can tell...
Hood is the same. 2014-2017. You will need the new 2016 plastic radiator cover that extends headlight to headlight. Grille, and complete bumper (2016 brackets and upper bumper trim). You will also need to trim the front wheel arch mouldings just a tad.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
