k&n cold air intake
boker
Been running K&N filters in racing motorcycles (Roadracing) and Audi cars for 35 years and will say flow is far better but slight dirt (talcum powder fine) can get past them if not kept oiled.
ZERO issues with engine longevity and that even applies to highly stressed air cooled Superbike motors of the past and current 1000,'s.
I will say this though, if I think of it, I put the paper filter back on for winter when the salted road dust is bad.....
    Dom Colussi
    Dom Colussi
  • Who's Online   5 Members, 0 Anonymous, 594 Guests (See full list)
