Clear coat options for engine enamel
Hi all, I'm working on a 454 for my truck, it's a 1993 1500 that I'm gonna put a 2012 one ton frame under that way I can run long travel ifs without having to do any fabrication that I don't feel comfortable doing, anyway, I was wondering if anyone knew of a clear enamel or something for engines because i have an under hood theme I want to stick with, the motors going to be natural aluminum with black powder coated accessories like the water neck, engine dipstick, accessories bracket, will be using a bracket from March performance because I'm going to run a Mezerie electric water pump, I'm going to remove inner fenders for increased wheel clearance, and will remove the factory coating on the frame and will have it clear coated.
I've already done some research into it and the reason I'm asking is I was planning on using duplicolor but I've read that it turned brown on a user's motor on some forum for I4 cars so I don't want that happening on mine and I don't know if with VHT if I would have to use some kind of colored enamel for it to stick and I'm not a fan of motors that are all painted so it's just one single color under the hood, almost seems like the easy way out, idk that's just me though, anyway, thanks in advance for the information
Sent from my A521L using Tapatalk
I have never found one.
DEI with its silicone is the greatest luck I have ever had.
always a color though.. no clear.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
