Brake light problem
I have a 1995 2500 5.7 and I've been having problems with my brake lights. They stay on even after the truck is shut off. I've looked around and was told to replace brake light switch and I did but did not fix the problem. So I've been just unhooking the battery, but evenly I was messing around with fuses, the fuse box under the hood and pulled the Aux B fuse. 30 amp fuse and it solved the problem. I want to know what that fuse controls and if it's important to keep it in or if having a dummy load there is fine.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
