dimming of all lights interior and exterior
Larry Ulmenstine
so i got a 03 escalade base model
when the car is in just battery mode. acc mode. w.e it dosent do this
but yet when i start the car. the whole time im driving or in idle. the lights dim in and out bright to darker. also this is all lights. everything that got lights.
i replaced the alt with a new one from autozone . new . lifetime warranty
still does it. when i pull the 4 pin off the alt .. it stops the issue. no more dimming
the battery was tested good as well.
now when i come to a stop at a intersection i notice that the car will idle funny and the voltage will drop to the 12s
the other issue as well is the cluster lights. all lights 90% of the time on my cluster will not light up except .. the park rev neut drive etc and the dummy display. sometimes they will come on. sometimes not.
might be the same issue or 2 diff issues. but either way im at a loss here. any ideals.?
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
