Diablo intune... which version?
djxn40
Maybe one of you guys with the intune can chime in and help me out as diablo tech support tends to ignore. I bought the diablosport intune i2030. I have looks all through the settings to try and find the version i2030 . I can't tell if it's a i2010 i2020 or i2030.
Wth??
No where on the package or in any of the software can i find this. Also I was watching a YouTube video of the i2010 version and it is identical to my software
Sent from my SM-N920P using Tapatalk
I believe that's more of a model number, not a version number.
The i2010 is for Chrysler vehicles, the i2020 is for Ford, and the i2030 is for GM.
Oh. Thank you for clearing that up.
