Ok so sometimes when I'm driving and mash the brake the first initial push on the pedal I can hear the brakes make a high pitched squeel but then after that it goes away then will maybe not happen for a little bit.
Lady said I have 8mm out of 10mm left on my pads.... is there a fix for this???
It's probably just one of them doing it, you could try figureing out which brake it is, take the pads out, put some brake gel on them, and reinstall them
Stupid question but is it wet out? OP never says. Moisture will cause even a brand new cars brakes to squeak, unless they squeak every single time this is usually the cause from what I know and it goes away once the moisture on the rotor has evaporated. Can happen on a nice morning even from dew depending on where you park. ex) on grass or similar.
Today it didn't do it at all and then randomly this afternoon it happened. It wasn't wet this morning!! What the heck?
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,266 Guests (See full list)
