Truck shifting out of gear
Mongo405
My gear indicator was in D the whole time I had the issue that is the first thing I checked. The update I got today is that it is an internal transmission issue and they will be going into it . At least they acknowledge the problem.
The transfer case neutral problem was a 14 to early 15 issue. I think this may have also only been a park issue. It was not a problem while driving, just a roll away type problem.
Amazing that you were able to get them to acknowledge a problem. That is the first step of any problem.
The gear indicator stays on D but because the truck is in 2wd the transfer case is not playing a role in movement. Now if I were in 4wd and was having the same problem the transfer case would be suspect, but all things being as they are, the transmission is the only logical suspect.
I'm glad that they are checking the internal workings of your transmission. They seem to believe that they can hook a computer to mine and magically fix the problem. If they get yours fixed let me know what they say. They are fixated on a computer issue with mine.
I will find out what exactly broke, but my trans definitely had something brake from the message I got letting me know that they had to order the parts to replace the damaged parts. I should have the truck back by Friday.
Got the Truck back today, it was the clutch assembly that broke and loss of 4,5 and 6th .They did a great job of finding the issue and fixing the transmission so quickly.
dudes what transmission are we discussing here the 6spd or 8spd?
Beast, that's great! I really happy to hear that your truck is back and that it's working properly. I was told that they were able to replicate the problem, and have some data about it, but they are consulting with the engineers at GM to figure out how to fix it. I was told that if it is an internal problem with the transmission that they would have to completely replace the transmission. I don't know yet if it's something like yours, or if it's a computer problem, but hopefully in the next couple days I'll get an answer.
It's the 8 speed transmission in my truck, that is the one I'm talking about
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,000 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
