Rock lights or underbody lights
Rock1500
Hello all.
So I was looking into either getting rock lights or under body lights for the truck. I was curious what is everyone take on either one. I want to tie them into the truck so when I open the door they turn on.
I was looking at lux rock lights or an underbody kit from xkglow. I would like to light up the ground pretty well. Not sure if I would stick to one color or do the multi color option.
What does everyone think or recommend?
Sent from my SM-N900V using Tapatalk
Definitely go with the multi color option. If you don't, you'll regret it. I'm going to be ordering my set in the near future
check out - www. recon.com - BIG rig lighting . running / turn . Your truck does standout at night in a parking lot . plus add a led tailgate strip your all set. This was on my Tahoe . SILVERADO has the same light strip , But the running lights ONLY works when doors are open . turn signal work like it should
That's quite an interesting site....
No kidding lmao.... would have been awkward clicking that at work...
It was great, opening it on my phone, next to my wife lol , her response was "WTF is that!"
All ready have a led tailgate light. Just looking to add a little under the truck mainly for lighting when I open the doors or still. Not looking to drive with the things on. No one in my area does that and not of interest. I did go to gorecon.com website and those are some powerful lights. But I might go with the color changing option for the fun of it.
Those rock lights are cool but expensive. They're probably made of good quality and durable. You could go with underbody light kits from streetglow or other manufacturers out there. I wired up a fire truck with reasonably priced lights and can't remember who made them but they're bright and industrial tough. You can search around. Good luck. And tying them into your dome light just search the forum. There's a couple threads that are great.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 548 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
