Largest tires with stock suspension
dvdprL
Sorry to start yet another one of these threads, but I cannot for the life of me find previous ones with the information I was looking for.
I have a 2016 Crew Cab 2500 Duramax. It is raised 5/8" in the front, and lowered 2" in the rear with drop shackles.
I'm looking for the largest tire size that I can fit on an after market 18" and aftermarket 20" wheel.
I don't want my wheels sticking to far out, so I know offset matters in regard to that.
I am looking to fit the meatiest tire possible. Just looking for my best options. If I need to crank the front to a full 1" and raise the rear 1", in order to fit a larger size tire I'm not opposed to that.
I installed 295/60 - 20 Pro Comp a/t sports on my 2016 duramax with out any level.. the fit is perfect
Do you have any photos?
As long as you're conservative with your wheel offset, you should be able to fit 295/55/20, 275/65/20 or 285/60/20 without any trouble. 295/60/20, 285/65/20, or 305/55/20 should also fit, but will be closer to rubbing. The last 3 may require a few extra torsion bar cranks, depending on your wheel offset. For 18's, you can run 295/65/18 or 285/70/18 easily. 295/70/18 or 285/75/18 should also fit, but might be close. Some guys are even running 35x12.50's with a level, but rubbing depends on the particular brand/tread of tire. If you're wanting the biggest possible, then go with a 35x12.50 and do what it takes (cranking or trimming) to make them fit. Otherwise, I really like the look & proportions of 295/70/18 and 295/60/20. To me, they look like 35's at a glance, when mounted on an aftermarket wheel.
    doylej24
    doylej24
  • Who's Online   5 Members, 1 Anonymous, 753 Guests (See full list)
