Catch Can @ 30K
Still am amazed at the amount of arguing that goes on about warranties and catch cans and MM warranty acts. There is a very simple solution to use one and not have any warranty issues.... have it set up so that if you need to go into the dealer for something, you can just disconnect the can quickly and reinstall one you get the vehicle out of the dealership! I can have my catch can uninstalled and everything back to stock in a few minutes with only a screwdriver. My can in mounted on the driver's side at the spare battery location, so no one is the wiser as to what it is for and I don't say, nor do I have to. I suppose they could void the warranty on my spare battery compartment!
And to get technical, the MM Warranty Act specifically addresses replacement parts, filters, brand names, etc and doing your own servicing on your vehicle, in that the OEM cannot blanket void a warranty for not using their brand of parts, oils, and components and doing the work yourself. It does not address add on components, modifications, engine tunes, etc. If you can find the exact wording in the MM Act that clearly states that it also applies to engine modifications, add on aftermarket components that change the original OEM design, etc, then please, by any means, post a link, a scan, or whatever to that text and enlighten the rest of us.
  • Replies 45
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
