Catch Can @ 30K
GM can't void your warranty for installing a catch can. If there were a warranty issue they have to prove the can caused it, whichis obviously impossible. If they are snake oil then why so they come with the 1LE camaros, new CTS Vs and ZL1s?
  • Replies 45
GM absolutely can and IS voiding warranties for catch cans. There was a post on here a while back about a new Camaro that had the engine implode due to oil pump failure. GM wouldn't even look at it because he had a catch can. A member on another forum I frequent was going to have his 2015 Sierra Denali transmission warranty claim denied because of an aftermarket CAI kit. The dealer told him to just put the stock intake back on or it couldn't fix his transmission. They were even questioning his custom exhaust, but he convinced them to ignore it. Sounds stupid, but it's the truth. For serious repairs, GM now requires a download from the ECM and a picture under the hood. Any modifications and warranty is gone.
And FYI, MMWA only covers use of non-OEM parts for repairs and maintenance, not necessarily power modifications. You can replace your OEM oil filter with a Fram one. You can use Pennzoil Oil instead of ACDelco oil. But you can't mod your engine in a way that it wasn't designed for using the same logic.
GM can, just like Ford can. There's a lengthy thread over on f150forums.com where a member installed a catch can in his 2.7 ecoboost. Well, he developed an oil leak and the dealer wouldn't cover the repair saying the can increased the oil pressure. He fought with Ford corporate and last i saw was looking at trading his truck in on a Tundra.
The auto manufacturer has to prove that something like a CAI or catch can caused or contributed to the failure. Just like they would have to prove that you did not run a dexos approved oil and that the non dexos approved oil caused the failure.
Quote from another website about voiding your warranty.
"If youre an auto enthusiast, chances are, youve heard the myth that modding your ride with aftermarket accessories automatically cancels your warranty. While this may be true in certain circumstances, you shouldnt take this as an absolute. According to the Magnuson-Moss Warranty Act, a vehicle manufacturer cannot void the warranty of your vehicle due to an aftermarket part unless they can prove that the aftermarket part was the cause of or contributed to the failure of the vehicle (15 U.S.C. 2302 ©). This means that a vehicle's warranty cannot be "voided;" the dealer can only deny a claim if the stock part failed due to damage or unreasonable use."
If your dealer tries to void a tranny warranty because of a CAI you are obviously at the wrong dealership.I know GM requires a snapshot of engine operating condition at the time of the faiure for major repairs but they are looking to see if it was operating at within designed parameters.
Adding an aftermarket part vs an oem part is one thing and thats what the Magnusson Act covers. A manufacturer can claim you altered the design of the vehicle by placing a catch can...not agreeing with it, but its stated in your warranty booklet.
exactly - swapping out one catback for another is one thing, however jabbing lines into your PCV & installing some intermediary between plenum & combustion chambers that was never designed to be there is something else entirely.
I am not sold on them, never have been, if you're that worried about it run a can of seafoam through once or twice a year.
BTW - I know its not DI but I use lucas fuel system cleaner & seafoam my Z06 every other year & the engine internals, valves, cylinder heads etc look like you could eat f*****g Sunday dinner off 'em
We have two 2014 silverado's in my companies fleet of work trucks with over 100k miles on them now. The engine has not exploded, power is fine, mpg is the same as it always has been. If my truck develops a problem that a catch can could have resolved then my solution is to dump the truck and go with a competitor and never give GM another dime of my money. I don't forsee this ever becoming a problem and if it does then I will probably be screwed anyway because eventually all the manufacturers will be going with DI engines.
The competitors are running DI engines too.. Well most of em, if they aren't now they will be. You'll need a catch can on those too, at least according to the catch can gods. :P
I am lucky in that I only drive my truck about 5k miles a year then! Should be a while before my engine explodes.
Damn... I've done like 6k in a month one time lol
Correct to some degree. The problem is that a catch can for us is not aftermarket, it's an engine modification. Similar to adding an "aftermarket" supercharger.
Also, I have posted previously two examples where GM has voided warranties based on photo evidence alone - catch can and CAI. I have not heard recently (last two years) of one person successfully maintaining a warranty with engine mods after a major failure requiring a photo. If you have, please share. People quote MMWA all the time, but it's very over-quoted. It primarily applies to OEM replacement parts, not alterations.
Which is why you keep stock parts and put them back on, unless you have a tune then it just sucks to suck
I had the 2-3 harsh/flare shift tranny ring seal & clutch plate TSB performed on my 2008 Pontiac G8 GT w/ the 6.0 & 6L80E @ 103,000 miles (reported the issues to dealer prior & was on good terms w/ them) - when they performed this warranty work (which absolutely required TCM programming or @ least looking through it) my car had JBA catless LT headers, magnaflow X pipe/axleback, a vararam intake, LS3 ported TB, livernois DOD delete cam (no more AFM new lifters/valves/springs too), dyno tune - this was in 2012
How you like them apples :driving:
Now....when I traded it in on my truck it had a low stall converter (2800) & 138,000 miles & I'm sure that would've been where they draw the line lol!
Anyhow...clearly I'm a gearhead geek & still maintain catch cans are waste of time/money & risk if you ARE worried about voiding warranty....I'd much rather have my warranty voided from a lopey cam, torque converter, badass stainless kooks headers etc. than a freakin oil CATCH CAN
Think about it that way lol
Still believe that running without a catch can is like running without an air cleaner, or worse, without a panty shield.
JMO, but that's just me.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
