door locks cycle & lights turn off
When I drive down the road, the door locks will attempt to lock, the battery meter will drop from about 15 volts to about 13 volts, the dash lights will cut off & back on, then the battery meter will begin to rise back to 15 volts. It will do this about every 3-4 minutes. At night, all the above will happen, but my headlights & dash lights will turn off for about 3 seconds, & this will happen every 3-4 minutes. If I lock the doors & wait about an hour, the key fob has trouble unlocking the doors. When it finally unlocks the doors, I turn the key to ON & all the lights on the dash come on, but the truck will not attempt to start until the locks cycle. If the fob will not unlock the doors, I have to unlock them manually & the alarm starts to chirp. I am not having any mechanical problems that I am aware of, just electrical.
I replaced the battery yesterday. I have checked the alternator while running. It shows about 14.8 volts & when I disconnect the battery, the alternator shows about 14.6. I have inspected the mega fuse & there are no signs of an arc. I have inspected the positive & negative leads off of the battery & the connectors, crimps, & the grounds look fine. They show about 15 volts running through them.
I appreciate any help. If this has already been covered, please send me a link.
Thanks
Well you can count out your FOB hanging on your key. Has to be your alternator kicking in and out.
I just replaced the negative battery cable& cleaned the ground connections. I'm still having the same problems. I guess I'll try replacing the positive cable & may try replacing the ground strap that goes from the back of the motor to the body.
Any other recommendations?
That ground strap between the engine and firewall is critical.
Make sure it is clean and tight.
I found some cable laying around & hooked it to where the ground strap is hooked on the body & attached the other end close to a spot I found by the alternator. I drove around for about 15 minutes with no problems (knock on wood). I'm going to try & find a cable with the proper connectors on it this weekend, instead of just wrapping copper around studs.
Any idea what size wire I need?
#2 cable and pick or have a battery shop crimp some ends on it for ya
Put a new ground cable on between the engine & firewall. Locks are still cycling every 3-4 minutes. I'm starting to get frustrated
