Dim PRNDL plague
potterc32
I have tried re-soldering the resistor on the circuit board. It worked temporarily, but started going dim again. If I press on the resistor with everything hooked up, it brightens up. But I can't seem to get it soldered down well enough. Any suggestions?
Clean the pad end of the mosfet with a good pc board cleaner and Use a good flux to transfer the heat then add solder to the board. Heat the joint of the mosfet as well.
    Gilkey96
    Gilkey96
  • Who's Online   4 Members, 0 Anonymous, 787 Guests (See full list)
